Neutral button on control lever fallen out
Author Topic: Neutral button on control lever fallen out  (Read 5466 times)
Wayne
  • Boat Model: Bavaria 37
« on: January 31 2014, 04:21 »
Hi Everyone,
Last week while on my boat I noticed that the neutral button on the control lever had fallen "off" the lever and onto the cockpit floor. I have a Volvo D1-30 engine on a Bavaria 37, 2007. The button does not have any serrated edges to indicate it has broken off a part that I cannot see. I put the button back in its slot and the neutral works fine but the button falls to the floor without tape holding it.
The lever is stainless but I can't readily identify the make of the lever.  Is the button attached by a split pin? Any ideas appreciated.
Devocean
Re: Neutral button on control lever fallen out
« Reply #1 on: January 31 2014, 10:34 »
Trapeze Artist
    • Little Hotels
« Reply #2 on: January 31 2014, 21:55 »
There's a rubber cover to hold the mushroom in place, which presumably you have lost. That rubber cover is supposed to be super-glued in place. Either it wasn't fixed well enough, or someone has removed it for dismantling and not used superglue when refitting. (It looks to me as if the rubber was designed to just press into place but it didn't work well enough, so the superglue was a last-minute fix.)
Insulating tape should do the job temporarily until you get a replacement rubber cover.
« Reply #3 on: February 01 2014, 14:04 »
You can get a kit from Lewmar with the plunger and the rubber cover. Outrageous price, but if you still have the plunger and the rubber just stick it back in. Sikaflex is better than the glue supplied.
Wayne
« Reply #4 on: February 06 2014, 02:48 »
Thanks for all the information. Lewmar Australia have a replacement kit at $60 AUD so will purchase and use Sikaflex instead of superglue.
Wayne
