Bavaria 36 Jib furling line
Author Topic: Bavaria 36 Jib furling line  (Read 4475 times)
MacLovin
  • Boat Model: 36
« on: October 10 2024, 17:43 »
Where the heck is the jib furling line supposed to run?
I have a 2003 Bavaria 36.
There is one block attached at the pulpit, then the fairlead and cleat aft of the winch.
Where should it go in-between?
Thanks in advance.
Re: Bavaria 36 Jib furling line
« Reply #1 on: October 10 2024, 19:18 »
it runs through a slot in the stanchion base. Works OK but better to use stanchion fairleads from Harken, Selden, Spinlock, Barton etc.
Keweetoo
  • Boat Model: Bavaria 35E
« Reply #2 on: October 12 2024, 12:21 »
I found running the furling line through the stanchion base slots produced a lot of friction and dirt on the line. Fitting stanchion fairleads 100mm up was much better together with a cam cleat/right angle block aft.
David Gray
« Reply #3 on: January 18 2025, 18:14 »
I have stantion mount eyelet and roller mount blocks fitted which you can buy from a y chandelry
