Bavaria 36 Jib furling line
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bavaria 36 Jib furling line (Read 4472 times)
MacLovin
Cadet
Boat Model: 36
Boat Year: 2003
on:
October 10 2024, 17:43 »
Where the heck is the jib furling line supposed to run?
I have a 2003 Bavaria 36.
There is one block attached at the pulpit, then the fairlead and cleat aft of the winch.
Where should it go in-between?
Thanks in advance.
Logged
Old Salt
Boat Model: B33
Boat Year: 2015
Re: Bavaria 36 Jib furling line
Reply #1 on:
October 10 2024, 19:18 »
it runs through a slot in the stanchion base. Works OK but better to use stanchion fairleads from Harken, Selden, Spinlock, Barton etc.
Logged
Keweetoo
First Mate
Boat Model: Bavaria 35E
Boat Year: 1999
Reply #2 on:
October 12 2024, 12:21 »
I found running the furling line through the stanchion base slots produced a lot of friction and dirt on the line. Fitting stanchion fairleads 100mm up was much better together with a cam cleat/right angle block aft.
Logged
David Gray
Cadet
Boat Model: Bavaria 36
Boat Year: 2003
Reply #3 on:
January 18 2025, 18:14 »
I have stantion mount eyelet and roller mount blocks fitted which you can buy from a y chandelry
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
