I recently noticed that when my fridge came on the led display fluctuated massively.
Subsequent checks showed that all the downstream readings were less than readings taken
directly from the battery with the fridge on.
When the fridge is not running they all agree.
I have an engine start battery which works in isolation to the two service batteries.
These are controlled by a selector 1,2,all, off switch.
I have wired the fridge compressor DIRECTLY to battery 2. (Battery 1 was through the normal circuit, under light load, everything normal). I had a wire running across the saloon floor from battery 2. Everything ran perfectly and after 48 hours the battery resting voltage was 12.3, running 12.0 which the boat has always been happy with. (I then change to the other battery giving me 4 days on battery power.)
I have changed the master switch but as the figures were the same I changed back to the original one.
I have taken the master switch out of the circuit and ran the switch panel positive directly down to a battery.
When under 240v charge there is no problem.
All 3 batteries charge to 12.8v and stay there resting for an expected amount of time.
I am at a loss as the batteries are good (48 hours under load)
The master switch is good (taken out of the circuit two different ways ... cable across the floor, switch panel wired direct to battery and then changed)
All the connections look/feel good but here are the observations:
Fridge off, all read the same.
Fridge on (sample numbers depending on state of battery when reading taken)
Battery 12.5
LED 11.7,12.1,12.7,12.5,11 whatever,12 whatever. Sometimes settles to following readings:
Bus bar (?). Positive stud, negative strip 11.6
Power socket 11.6
Instrument panel 11.6, BUT wind, gps, speed, depth, pilot all run fine. They have actually been on when I opened up the instrument panel and took the readings.
I’m totally lost.
The volt meter could be suspect but it ALWAYS gives the same readings wherever I test i.e. battery says 12.3, bus say 11.6 ... consistently.
The good news is that everything works.
The fridge runs 10 mins on, 20 mins off (on average), the instruments, water pump, lights all work.
If it hadn’t been for the led giving such crazy figures I would never have known there was a problem.
My wife is leaving me as all I do now is jump up every time the fridge starts, throw everything off the seat to test the battery, check the led, mutter, sweep everything off the chart table to get to the bus bars, plug the gps into the socket and dash into the cockpit to take readings.
And mutter.
Actually sometimes I don’t domall that, everything is clear but then half the boat is inaccessible.
Sorry for the length of this post but 7 pages of readings on, off, different start voltages, scribbles, not sure what I wrote has taken its toll
