Swim platform gas spring Bavaria cruiser 40 2013
Author Topic: Swim platform gas spring Bavaria cruiser 40 2013  (Read 6136 times)
Nicolas235
  • Boat Model: Bavaria Cruiser 40
  • Boat Year: 2013
« on: July 02 2018, 18:53 »
Anybody has experience in replacing these. Mine have absolutely no force to them anymore. I have to lift the whole weight of the platform when I put it down or up.
These units are available through SVB
https://www.svb24.com/en/bavaria-gas-pressure-spring-for-cruiser-32-swimming-platform.html
They are labelled for Cruiser 32... I am reluctant to order them for my cruiser 40. Anybody KNOWS that these units are the ones I need?
burakkilic
  • Boat Model: Bavaria 40 Cruiser
  • Boat Year: 2012
Re: Swim platform gas spring Bavaria cruiser 40 2013
« Reply #1 on: June 14 2021, 13:58 »
Any luck about fixing that? I have exactly the same issue with my Bavaria 40 2012. One of my friend who had the same issue fixed it replacing the gas springs with custom made ones. They were 2300N springs.
David Light
  • Boat Model: Cruiser 32
« Reply #2 on: February 20 2023, 17:52 »
What is the size of your swim platform? The rating of the gas spring will be to overcome the weight of the swim platform. If your Cruiser 40 platform is the same size as my Cruiser 32 platform, it stands to reason that the gas spring will have a similar rating.
I documented the replacement process here: https://bavariayacht.org/forum/index.php/topic,3921.0.html
Franck Bavaria
  • Boat Model: Bavaria 41 cruiser
« Reply #3 on: June 19 2024, 20:18 »
Did you find out which gas spring stregth and dimensions fit your Bavaria Cruiser 40 swim platform ? My 41 Cruiser would be the same, and I also need to change them.
lasmotta
  • Boat Model: Cruiser 41
« Reply #4 on: January 04 2025, 22:36 »
Hi Franck, have you found where to buy the correct gas spring for the Bavaria 41 swim platform?
The spring on my platform (Bavaria 41 2014) stopped working completely a week ago.
