Which "POD" for Bavaria 36 pedestal?
Author Topic: Which "POD" for Bavaria 36 pedestal?  (Read 5127 times)
fyndi
« on: April 21 2015, 18:45 »
Hi everybody. I'm new member in this forum and I would like to ask your help. I recently bought Bavaria 36 ym. 2003 and now I will renew plotter and replace Raymarine log, rudder data and tridata in pedestal. But what kind of "POD" I should buy to attach into Bavaria's pedestal? All the models which I have found, don't fit to mine boat. Typically those pods are designed to fix to two vertical tubes, but in my boat there is horisontal tube. Please see pictures.
Can you help me and advise where i could find pod which will fit into my boat?
Re: Which "POD" for Bavaria 36 pedestal?
« Reply #1 on: April 22 2015, 10:26 »
This is the way I solved the problem, The marine pod has adjustable mountings, not cheap but no more than Scanstrut mounts also very well constructed. Go for the stainless steel mounts they look great
http://www.mesltd.co.uk/files/marinepod_brochure.pdf
BillGiles
« Reply #2 on: April 22 2015, 18:02 »
About £200?
mick50
  • Boat Model: bavaria 38
« Reply #3 on: April 23 2015, 14:19 »
on the same topic does any one know were you can buy a new facia for the pedestal. ive been looking to fit a chart plotter in mine and move the other instruments into a pod
plover
« Reply #4 on: April 23 2015, 18:11 »
I recently had a new fascia made at a local plastics shop. (TAP Plastics)  Removed the old one and had them use that as a template.  Won't look exactly like the original - but close enough.
fyndi
« Reply #5 on: April 23 2015, 20:01 »
Thanks for pictures Moodymike. If you don't mind, I will copy that installation and buy also marine pod. Now when I know the model, I even found local dealer for it.
