fuel tank grommets
Author Topic: fuel tank grommets  (Read 6047 times)
fuel tank grommets
« on: April 16 2015, 14:51 »
Anyone got information or diametions of these grommets.
UC-2802.   8mm
One of mine has started weep so need to do something about them. I can get grommets from lots of places but need diametions or a known suppler of the part. I am already talking to Clipper but no response yet.
Boat in France so cannot measure them. I thought it would be easy to get spares!! But!!
So, looking for tank hole size and thinkness, I can work the rest out.
Bav 38    2006
Re: fuel tank grommets
« Reply #1 on: April 16 2015, 18:04 »
« Reply #2 on: April 19 2015, 13:55 »
These look the same as the flow and return fuel pipes. Are they simply a push fit? I presume there is a tube going to the tank bottom. Do you know the purpose of the connection in your picture?
« Reply #3 on: April 19 2015, 14:17 »
Its a fuel visual level indicator, however I use mine to sample fuel from bottom of the tank and a supply fuel to my webasto.
The grommets are push in type and an 8mm pipe goes through it.
See my posts before.
Bav 38
gam1961
  • Boat Model: Bavaria 30
« Reply #4 on: January 24 2017, 23:07 »
UC-2802.   8mm
Bav 38    2006
8mm grommet is for
Found a UK supplier
http://www.phoenixmarinesolutions.co.uk/Products/Parker-UCC-Return-Bushes/2802
Bav 38
Clipper Marine can supply these grommets cheaper than Phoenix.  8mm for sighting tube.  12mm for fuel our and return tubes.
« Reply #5 on: January 25 2017, 09:56 »
I have 8 left over if people have a probelem getting them.
Bav 38
