Replacing fuel gauge
Author Topic: Replacing fuel gauge  (Read 4052 times)
skipper
  • Boat Model: bavaria44
« on: March 25 2015, 22:26 »
2002 Bavaria 44. Fuel gauge in poor condition so I want to replace it. I have checked various sites such as Volspec & Keypart, but it appears that the gauge is a standard 52mm vdo unit available from many outlets online and ebay. Can anyone tell me the right one/type please?
I need to get a replacement before I destroy the old one taking it out. The body has rusted and jammed itself into the hole so it looks like a hammer and chisel job.
I have tried to post an image but I cannot understand the instructions.
Thank you,
Michael.
Re: Replacing fuel gauge
« Reply #1 on: March 25 2015, 23:02 »
If you look on the online VDO catalogue you will find good illustrations and specs of their range of instruments.
« Reply #2 on: March 26 2015, 00:54 »
Note that there are different types, sender resistance and polarity. It should tell you the resistance of the sender at the bottom of the instrument scale.
« Reply #3 on: March 26 2015, 10:07 »
I replaced mine last year for the same reason (even though it still works) and the only supplier I could find for these is Bavaria as they are specifically manufactured to match the fuel tank sender. Either change both or go to a Bavaria agent. Cost is about £57
