Doors under bunk in the forecabin on a Bav 38 2004
Author Topic: Doors under bunk in the forecabin on a Bav 38 2004  (Read 11144 times)
« on: February 10 2012, 15:04 »
Has any one put doors under the forecabin bunk, if so any photos would be good.
Seen it done on the USA site but wanted to get some one to one info.
Thank
tony from dorset
Re: Doors under bunk in the forecabin on a Bav 38 2004
« Reply #1 on: February 10 2012, 21:07 »
no not done it but it is my next project as i am totaly   pxxxxxxxxxxxxxxx off  having to lift the bedding each time you want to remove  something from under the bed why oh why did they not do it from new. i am going to make a one peice removable like the rear aft cabin access into the stern with two swing clips. i shall not make it huge just big enough to gain access.
« Reply #2 on: February 13 2012, 11:08 »
I think to cut any sort of hole will need the bunk reinforced at the top inside, I have measured the bulkhead and its in the order of 20mm so OK, but when a hole is cut I can see it sagging.
 Got to be some chippies out there, give us some input please
Sweet As
« Reply #3 on: February 14 2012, 10:38 »
We have the modification on our 2004 Bav 36, performed by a previous owner. It is a single quite large opening, piano hinged at the bottom. Works really well for us.
I would add a pic if I knew how to from this iPad. Help with this would be greatly appreciated.
Sweet As
Bav 36
« Reply #4 on: February 14 2012, 16:00 »
Love to have the photos when you get then sorted, the more you have the better.
tony from dorset
« Reply #5 on: February 14 2012, 21:07 »
yep some photos would be good  but being 20mm ply i dont think you will get any sag, i was down at weekend checking mine out and i am planing an opening of approx 450 wide and 450 high just big enough to get some cockpit cushions stowed away and some bags etc
Sweet As
« Reply #6 on: February 15 2012, 09:34 »
Hopefully you will be able to view the pics attached??
Sweet As
Bav 36
Sweet As
« Reply #7 on: February 15 2012, 09:36 »
.......and the other one, with the door closed!
Sweet As
Bav 36
« Reply #8 on: February 15 2012, 10:41 »
Just what I wanted, is it possible to take photos of the inside construction and any strengthening that has been put in. for the photos you can go through my email address on my web site, this will let you send good size files.
www.scanmar-odysseus.co.uk
Are you on the south coast??
Thanks again
Odyssues
« Reply #9 on: February 15 2012, 10:53 »
How did you manage to get such a neat cut in thw woodwork?
Sweet As
« Reply #10 on: February 15 2012, 21:44 »
Thanks again
Odyssues
I'll get more detailed pics and fwd thru in the next couple of days.
No, I'm on the east coast....................................of Australia ;D
Sweet As
Bav 36
tony from dorset
« Reply #11 on: February 16 2012, 19:57 »
that looks a really smart job whoever did it.  looking at the grain lining up and overall finish could this have been a factory fitted job?
KAOS
  • Boat Model: BAVARIA 38
« Reply #12 on: February 19 2012, 20:16 »
My 99 Bav 38 Holiday had it as standard.
