Gas tap
Author Topic: Gas tap  (Read 5162 times)
Tethys
Gas tap
« on: September 25 2014, 12:49 »
Does anyone know of a source of cabin gas tap, i.e. the one with the big red handle and the same as the fuel shut-off valve?
Thanks,
Andy
Tethys
Re: Gas tap
« Reply #2 on: September 25 2014, 15:25 »
Excellent, thanks for the links.  Just have to ascertain the exact version now.
Regards,
Andy
Re: Gas tap
« Reply #3 on: September 25 2014, 16:55 »
Last year I had a leak from the original tap in the closed postion.  Changed it for a ball valve type from Socal Southampton.  Did involve modifying the pipe run.  You may find the original fitting diffcult to dismantle ,had to cut mine off with a Dremel.
http://www.socal.co.uk/toolbox/installation-components/taps-valves/floor-mounted-mini-gas-ball-valve-5-16-compression.html
Re: Gas tap
« Reply #4 on: September 26 2014, 10:34 »
Both of the original taps are rubbish, change them for ball valves.
Tethys
Re: Gas tap
« Reply #5 on: September 27 2014, 13:28 »
Thanks for the additional info.
Regards,
Andy
