MD2030 - installing temperature sensor
Author Topic: MD2030 - installing temperature sensor  (Read 4329 times)
Sweet As
« on: June 16 2014, 12:01 »
I would like to install a temperature sensor and gauge in my 2004 Bav36 (MD2030). There appears to be a bolt on the stbd side of the engine block that looks like it would open into the cooling water jacket. I assume this is the location one would screw a temperature sensor in to. Has anyone done this and are you able to advise of an available sensor that would screw straight in?
Sweet As
Bav 36
Re: MD2030 - installing temperature sensor
« Reply #1 on: June 16 2014, 15:49 »
I think the temp sensor screws into the heat exchanger.  Any Volvo Penta dealer would be able to confirm this, and supply a sensor and gauge which will work properly.
