Calorifier for '97 Bavaria 38
Author Topic: Calorifier for '97 Bavaria 38  (Read 5375 times)
14chops
  • Boat Model: Bavaria 38H
  • Boat Year: 1997
« on: June 05 2014, 19:15 »
Does anyone know the dimensions of the calorifier installed on a '97 Bavaria 38. Mine has started to leak and needs replacing. Forgot to measure it before leaving to come back to the UK. Thanks.
AB1707
  • Boat Year: 1997
Re: Calorifier for '97 Bavaria 38
« Reply #1 on: June 19 2014, 10:28 »
I have a 1997 Bavaria 38 Ocean. Our calorifier is a Quick Boiler B3 15l capacity.
Length 405mm
Diameter 316mm
Width of foot supports 355mm
Here's a link for the manual for mine if it helps all dimensions inside
http://www.quicknauticalequipment.com/resources/downloads_qne-prod/1/Man04B_BoilerB3_15-80.pdf
Regards
Adam
14chops
  • Boat Year: 1997
« Reply #2 on: June 22 2014, 18:56 »
Thanks Adam.
A lot quicker response than I'm getting from Bavaria. I'll check out the info you've provided. Sounds like it must be of a similar size / capacity..
Cheers.
Paul.
