Warning to Volvo Penta Owners: Oil Change
Author Topic: Warning to Volvo Penta Owners: Oil Change  (Read 5255 times)
« on: February 01 2014, 09:21 »
I don't know if this applies to all Volvo Penta engines, but I just discovered that the oil suck-out pipe does not reach the bottom of the sump on my MD22. Last time I changed the oil I noticed that the oil on the dipstick was not clean. This year I bought a 1m length of PVC tubing to fit inside the suck-out pipe. I emptied the oil as normal, then pushed the smaller tube in until it stopped, I got out at least another 500ml.
Next time I'm going to try a more rigid tube, and a more permanent join to my pump. An 8mm drill bit fits quite loosely in the pipe.
Some of you may already know this, but I thought it was worth a mention as the VP manual shows a pump attached directly to the pipe.
For a related question regarding the dipstick, see this poll.
Anthony
Re: Warning to Volvo Penta Owners: Oil Change
« Reply #1 on: February 02 2014, 21:18 »
You can also access the sump plug nut via the starboard side door and slide a shallow baking tray under with an oil blotter fabric inside to get the last of the oil.
I always leave a suitably cut section of oil absorbent pad in the well under the engine. It saves smell and mess.
MIA
« Reply #2 on: February 04 2014, 17:07 »
When I change the oil I first run the engine to heat the oil, then suck it out with the suction tube, I then measure the amount that has been removed and normally get majority out
Bertybuoy
« Reply #3 on: February 15 2014, 10:54 »
Usu the outer sheath of a Bowden cable as it is flexible, weighted and small enough to get to the bottom of the sump. Slows you down a bit, but if the oil is warm it's not too bad and well worth the extra time!
« Reply #4 on: February 18 2014, 02:11 »
You can also access the sump plug nut via the starboard side door...
I looked for one, but couldn't see it. Do by any chance have a picture?
