Shore power plug
Author Topic: Shore power plug  (Read 4579 times)
Sweet As
Shore power plug
« on: January 04 2014, 22:33 »
I am having trouble at times easily removing the three pin shore power plug from the transom of our 2004 Bav36. The problem is high friction between the pins and the plug. Does anyone have a really effective trick for helping this plug to slip off without so much force that one fears pulling the plug apart? Cleaning the pins with emery paper from time to time helps a little.
Sweet As
Bav 36
Re: Shore power plug
« Reply #1 on: January 06 2014, 09:26 »
Assuming this is a standard 16A blue plug...
You do know about the release catch?
Any friction is probably the plastic, this is probably the only electrical connection on my boat where I still use WD-40.
Sweet As
« Reply #2 on: January 07 2014, 09:41 »
Thanks Nigel,
Yes it is the blue plug and I am aware of the lock/release mechanism. I will try lubricating the plastic casing. I had just assumed that the issue would be the melt to metal contact.
Sweet As
Bav 36
iain789
« Reply #3 on: January 12 2014, 13:11 »
I had the same problem. I found a light smear of Vaseline on the pins did the trick. (No doubt someone will be along to give lots of reasons why you shouldn't do that, but it worked for me.)
