propeller size for 2003 Bav 38
Author Topic: propeller size for 2003 Bav 38  (Read 5863 times)
stevem
  • Boat Model: Bavaria Vision 42
« on: December 27 2013, 00:29 »
Does anyone know the prop size for a 2003 Bav 38 fitted with the volvo D2 55HP engine?
I seem to be getting conflicting advice fr0m different dealers.
Re: propeller size for 2003 Bav 38
« Reply #1 on: December 27 2013, 17:34 »
My bav 40 ocean with md22 50hp uses a 17x14L , my guess is about the same or 17x15L. Geoff
stevem
« Reply #2 on: December 27 2013, 18:20 »
Thanks Geof,
I forgot to mention that the prop in question is a three bladed fixed.
The boat is in Greece, thats why I cannot check it. .gonna try to buy a new one at the boat show.
Regards,  Steve
« Reply #3 on: December 28 2013, 14:39 »
Hello Steve.
If you want to buy a new Prop at the boat show you will always need to mention your type of boat, engine, building year, etc. They wont have the right prop on the shelf for you. So they will gather your boat data, and a good dealer/maker should know Bavaria 38/55 HP Volvo/Saildrive/Gear reduction ratio +++, and being able to recommend the right prop. Either they give you an offer at the show or later by mail so you can decide.
Good luck with the search.
here you can download an Excel Prop-Calculator
http://www.alberg30.org/maintenance/MechanicalPropulsion/Propeller/propcalc.xls
« Reply #4 on: December 29 2013, 00:06 »
If you are buying an original equipment fixed prop then the dealer will recommend the size. suggest you check first with Clipper Marine who will have the original spec. If you are buying a folding or feathering prop again the supplier will recommend a size, which may not necessarily be the same as a fixed prop.
« Reply #5 on: December 29 2013, 06:43 »
Ask any Volvo Penta dealer in the UK, by email. They will need all the info as previously mentioned.
