Bavaria 36 Holiday 1998 - Shower in Head ?
Author Topic: Bavaria 36 Holiday 1998 - Shower in Head ?  (Read 3294 times)
Voilanges
  • Boat Model: 36
« on: November 28 2024, 13:53 »
Hello,
I'm about to buy a Bavaria 36 Holiday but it seems the is no shower in the head ?
There's a tap without a showerhead above the sink.
Is it possible to add a showerhead ?
Is there a pump at the bottom of the wet room to empty the water from the shower?
Is it possible to adapt it?
Thank you for your help
Keweetoo
  • Boat Model: Bavaria 35E
Re: Bavaria 36 Holiday 1998 - Shower in Head ?
« Reply #1 on: November 28 2024, 15:00 »
You should find the tap head is on a hose and you pull it out  - a button on the head selects spray or stream  - there may be a wall bracket to fit it to, or otherwise they are simple to install. You should also find there is a pump-out button, usually by the sink (with power isolator on the control panel).
Stevie H
« Reply #2 on: November 28 2024, 17:01 »
I have a 1999 B36 Holiday.
My heads sink tap is as described by Keewetoo and like this example:   https://www.jacksonsleisure.com/caravan/motorhome/reich/trend-e/julia/shower/mixer/tap/571-500000661/   I replaced mine a few years ago and there are numerous options at cheaper prices on the web.
If you have a pumped drain there will be a waste outlet in the floor of the heads and the pump will be mounted in the cupboard under the sink.
If your tap has no pull out shower I would think either it was originally and option or the original tap has been replaced by a previous owner. If there is no waste outlet that would suggest either it was not available at the time or was an option.
 I would think it is possible to fit both a drain outlet and pump  -mine tee's in to the basin waster pipe that has its own thru hull discharging out the side of the hull.
Voilanges
  • Boat Model: 36
« Reply #3 on: November 28 2024, 18:11 »
Thank you for your answers.
The tap is not a real issue, but the drain might be a greater one.
I'd look at the boat in a few days.
On the pictures, I can see a drain on the floor, so I asked myself how difficult is to create one if necessary
Samoerai
« Reply #4 on: December 02 2024, 16:11 »
Just to confirm,
our B34 from 2000 doesn't have a shower and a pump either. Although I do see a spot where maybe a pump could be fitted, it doesn't look that easy.
