Volvo md 2030 will not achieve full rpm in gear
Author Topic: Volvo md 2030 will not achieve full rpm in gear  (Read 3038 times)
Mcalan
  • Boat Model: Bavaria 36 C
« on: October 17 2024, 08:13 »
After a complete engine rebuild the engine will only reach 2000 rpm in gear but 3600 in neutral
Air filter new
Exaust elbow new
Valve timing checked
I suspect that the throttle arm is not in the correct position but don’t know how to reset it ?
Happysailor
Re: Volvo md 2030 will not achieve full rpm in gear
« Reply #2 on: October 18 2024, 16:55 »
You can visually check whether the lever on the engine is hitting the stop when the control lever at the helm is at maximum. Achieving 3600 in neutral as little as with no load it does not require much fuel. Is the 2000rpm under way or tied up to the pontoon? Quite normal not to reach high rpm in the latter, although it should be higher than 2000. Two main causes of low rpm under load are insufficient fuel/air mixture and overloading for example because of the wrong propeller or a heavily fouled propeller.
