Rev counter working intermittently
Author Topic: Rev counter working intermittently  (Read 5027 times)
Scallywag too
« on: November 03 2013, 16:18 »
My rev counter only works some times I have tried checking the connections can someone tell me what wires I should be checking  or could it be something else
Brian
Re: Rev counter working intermittently
« Reply #1 on: November 04 2013, 09:13 »
I believe that terminal W on the alternator is the sensing terminal for the  rev-counter,  worth checking and cleaning.
Scallywag too
« Reply #2 on: November 04 2013, 18:31 »
Thanks I'll give it a try next time I'm at the boat
Anthony
« Reply #3 on: November 11 2013, 00:12 »
I have noted many Volvo engine hour meters not running at all; replacement is hideously expensive but for less than AU$20 inc postage can get quality functioning waterproof hour meter from Hong Kong. Just attach across ignition circuit... in my case just used the fuel meter circuit which also turns on when ignition turned on.
« Reply #4 on: November 15 2013, 07:57 »
I have noted many Volvo engine hour meters not running at all ...
For Volvo engine hour meter replacement, see the Downloads section.
