Headlining Colour
Author Topic: Headlining Colour  (Read 3223 times)
Scorcher IV
    • Ease the Sheets
Headlining Colour
« on: September 24 2024, 19:53 »
Hi, does anyone know of a supplier for the headlining material which is a foam backed vinyl. I am also after the original colour chart for Bavaria. I have a C37 which has been leaking through the two fixed windows in the deck behind the mast. The backing ply is rotten as a result of the leaks but will be easy enough to remake. Just need the vinyl to cover it now.
Simon
Re: Headlining Colour
« Reply #1 on: September 24 2024, 20:13 »
Look at the Hawke House website.
Happysailor
« Reply #2 on: September 24 2024, 21:03 »
On our previous Bavaria 300 from 1990, I experienced the same problem and I completely refurbished the interior with the same foambacked vinyl as used in later Bavaria’s.
The manufacturer is Dutch, but their supplies are available globally:
https://vyvafabrics.nl/en/product/head-and-hull-lining/head-and-hull-lining/viva-cover-white
You will need to glue this with specific solvent free glue which is a bit tricky to work with. The bonding does not immediately take place so in my case I needed some additional hands to glue the panels in situe again
Scorcher IV
    • Ease the Sheets
« Reply #3 on: September 24 2024, 22:39 »
Thanks for the information and advice.
