Clamp fittings on toe railing base explosion: alternatives or DIY ?
Author Topic: Clamp fittings on toe railing base explosion: alternatives or DIY ?  (Read 3327 times)
Franck Bavaria
  • Boat Model: Bavaria 41 cruiser
My both clamps on toe railing litterally exploded in tiny pieces (my pics are too large, I could not upload them for now due to forum restrictions)
I checked for replacement and found them:
https://www.svb24.com/en/bavaria-clamp-fitting-on-railing-base.html
No less than 620€ for identical, poorly designed, clamps: huge galvanic corrosion between aluminium and stainless steel that led to explosion
Any alternatives to suggest ? Or DIY solutions ? My boat is a 2014 Bavaria 41. Those clamps hold my bimini tubing.
Many thanks !
Franck
I read it as 260€...
Use Duralac or similar to minimise galvanic corrosion.
Franck Bavaria
Thank you for the tip about duralac. It is also called tefgel. 310€ x 2 = 620€
