New cable inside pulpit
Author Topic: New cable inside pulpit  (Read 3678 times)
Ailatan
« on: July 05 2024, 07:23 »
I have to modify the pulpit because the current one is too big for a code 0 and in the process I was thinking of renewing the cable that runs inside the pulpit.
As the room is very tight I am afraid of losing the guide. Anyone has done it and can give me advice?
I read that the cable has to be of a special type to avoid corrosion by the sea water, any advice on that?
Thks in advance.
Re: New cable inside pulpit
« Reply #1 on: July 05 2024, 08:03 »
The cable needs to be tinned. You can attach the new cable to the old to pull it through.
Ailatan
« Reply #2 on: August 12 2024, 22:40 »
For de benefit of others, I thought that the cable followed the shortest way but instead it follows the green line
