Oil leak on saildrive of a MD2030
Author Topic: Oil leak on saildrive of a MD2030  (Read 2192 times)
JM
« on: May 15 2024, 00:18 »
Hello,
There is a small oil leak on the bottom of the saildrive of my Bavaria 36 2003.
The engine is a MD2030.
The leak seems to come from a small hole as shown on this image.
Any help would be appreciated
Re: Oil leak on saildrive of a MD2030
« Reply #1 on: May 15 2024, 08:16 »
That is the drain plug hole. The plug is screwdriver slotted but very a wide slot 2 or 3mm. Under the head of the plug is a nitrile O ring , maybe missing ? Geoff
« Reply #2 on: May 15 2024, 09:27 »
Should be a 130 model. Hard to see, but the oil is barely visible. It's not coming from the drain plug (that's where the green tape is), but from one of the water intake holes. That means either the internal water channels have corroded away or the gasket between the leg and the gearbox has failed. Or someone tried to clean the water passages with a drill or some such.
You can try and fit a borescope inspection camera in there if it fits and maybe see which problem it is, but either way the saildrive needs to come out and the leg split from the gearbox. Maybe the service (replacement of the rubber diaphragm and also the gasket in question) is due anyways.
marioxp
« Reply #3 on: May 16 2024, 07:29 »
Have you noticed if sea water has entered the oil, is the oil milky?
What is the oil level on the dipstick in the saildrive?
JM
« Reply #4 on: May 17 2024, 14:17 »
Thanks. I will take the saildrive out and check both. Thanks again.
JM
« Reply #5 on: May 17 2024, 14:21 »
Thanks for your help.
A water infiltration issue was dealt with last year. It seem that the problem is a gasket.
The oil level does not change because the leak is very small and the dipstick is also very small. Very difficult to evaluate.
Thanks again.
