Muffler
Author Topic: Muffler  (Read 2623 times)
marioxp
Muffler
« on: April 19 2024, 11:17 »
My original muffler 46mm leaked.  I remember you saying that some of you had Vetus plastic put in and were satisfied.  Which model would you recommend?
https://www.svb24.com/en/category/waterlocks-mufflers-for-boats
Re: Muffler
« Reply #1 on: April 19 2024, 11:38 »
WLOCKLR 45mm. The one showing as LP in the SVB catalogue as LP which is the "family" name for that type but is actually the model for 30mm. JUst make sure you order the 45mm option. Also worth considering having the Volvo one repaired if it has corroded around the outlet. I had mine plated with stainless for around£50.
Krumelur
Re: Muffler
« Reply #2 on: June 09 2024, 08:50 »
Maybe a stupid question, but where is this thing located? Could it be that it is underneath the fuel tank on my 40?
Re: Muffler
« Reply #3 on: June 09 2024, 18:15 »
Usually in the port aft cabin beneath the bed . Follow your exhaust hose starting from the engine
Re: Muffler
« Reply #4 on: June 09 2024, 22:48 »
Depends on the engine and the rear cabin layout. The MD22 exhaust is on the starboard side and the D2 is on the port side. As suggested follow the exhaust hose and the muffler is under the bunk alongside the tank. You can't miss it!
marioxp
Re: Muffler
« Reply #5 on: June 10 2024, 06:05 »
This one is located on port side.
