Quick charger sbc300nit charging
Author Topic: Quick charger sbc300nit charging  (Read 2717 times)
elias
« on: January 26 2024, 15:38 »
When plugged to shore AC starts (I can hear the fan ) and then it goes on the mode as in the photo . From the manual I understand that the power light should be open and status screen on . Any ideas? Tried with load to (running the fridge etc ) to wake it up no luck . Battery state with multimeter at 12.35
elias
Re: Quick charger sbc300nit charging
« Reply #1 on: January 26 2024, 15:40 »
« Reply #2 on: January 26 2024, 15:53 »
It's probably seen better days.  When my charger died, I replaced it with a Victron Blue Smart IP22 charger (30A, 3 outlets).  It's an excellent little charger, quiet and efficient.
https://www.victronenergy.com/chargers/blue-smart-ip22-charger
elias
« Reply #3 on: January 26 2024, 18:29 »
You think it shouldn’t even checked for some fuse inside ? Did you had similar issues ?
« Reply #4 on: January 26 2024, 18:37 »
The factory-fitted charger on my boat was a Cristec.  I looked inside for fuses, burnt components, etc, but all looked fine.  Cheaper to replace than to try to find someone to fix it.
elias
« Reply #5 on: January 27 2024, 08:26 »
Going for victron too , thanks !
« Reply #6 on: January 27 2024, 10:57 »
You may be surprised by its size!
« Reply #7 on: January 27 2024, 14:06 »
We went with Sterling, because it could fit in the boat! :-)
And the previous Sterling had lasted 20 years, which is a reasonable lifespan for such things. I did have a look at fixing the old, but the broken components were hard to find after this time and likely more would've failed soon after, so it made sense to renew.
« Reply #8 on: January 27 2024, 14:30 »
My comment about the Victron was referring to how small it is!  I was amazed when I opened the box it came in.  The charger is only 235 x 110 x 65mm - less than half the size of the equivalent Sterling product.
elias
« Reply #9 on: January 27 2024, 19:45 »
Just installed it , amazingly compact indeed !
I have to comment also that I am dissatisfied with the quality of the wiring on Bavaria 50 2007 . On my Bavaria 44 2003 the battery wires are tinned , in the 50 not.
