Change anchor light bulb
Author Topic: Change anchor light bulb  (Read 2936 times)
Ailatan
« on: January 08 2024, 09:23 »
All my navigation and interior lights are led with the exception of the anchor light.
Now I want to replace this anchor light but I would like to do it in one go.
Does anyone know what type of light bulb I need to buy? I understand that all the Bavaria's of the 2000s and larger than 40 feet used the same light
Re: Change anchor light bulb
« Reply #1 on: January 08 2024, 10:01 »
See photo
Bav 38
« Reply #2 on: January 09 2024, 06:10 »
Or at the same time while you are up there - upgrade to tricolour - anchor light combo
https://www.marineled.fr/en/navigation-lights/72-tricombo-navigation-bay15d.html
This is my mid-term plan if changing from archipelagic sailing to more offshore-oriented sailing.
BR,
Tommi
s/y Anniina
Ailatan
« Reply #3 on: January 09 2024, 09:30 »
Thanks both for the advice.
The dusk and down sensor is a good extra because it won't be the first time I've forgotten to switch the light off at down.
Tommi, regarding the tricolour option, do you know if changing the current anchor light for the tricolour option is easy or I will need to drill new holes?
« Reply #4 on: January 09 2024, 10:45 »
Ailatan,
I have not installed one myself, but based on my YT "research" https://www.youtube.com/watch?v=5C9BhxqwR7Y it should be pretty much a plug-and-play solution - the only thing you need aloft is an extra screwdriver to adjust / ensure correct sector alignment.
Tommi
s/y Anniina
Ailatan
« Reply #5 on: January 09 2024, 18:31 »
Thanks for the video. Now I got it. First time I thought it was a complete fixture, but now I see it's a very smart light bulb
Joe
« Reply #6 on: January 10 2024, 11:21 »
Ailatan,
Tommi
s/y Anniina
Tommi,
We have installed the Tricombo but unfortunately it completely disturbs our AIS signal. So please don‘t be surprised if you are suddenly alone on the ocean if you switch it on.
Joe
« Reply #7 on: January 10 2024, 11:31 »
Joe
Thanks Joe for this info... need to think again or consider installing additional AIS antenna off masthead wiring route.
Tommi
Ailatan
« Reply #8 on: January 10 2024, 22:03 »
Thanks Joe, that's a good point
