Ocean 47 galley worktop dimensions
Author Topic: Ocean 47 galley worktop dimensions  (Read 1730 times)
« on: December 31 2023, 16:46 »
Long shot I know but maybe someone can help. I plan to  renovate my galley worktop by overlaying with 10mm laminated plywood (fiddle height will be reduced but that is not an issue. It can be tricky  to  find the right material in Turkey and as I have some offcuts at home I thought to  use them up  for this job only I am not sure I have enough. I need to   know the length and width including the projection for the fridge, and the position of cooker sides. I'll replace the sink unit with something better so cut out is not an issue. If there was a boat in the Uk I could make a template. Thanks
