Holding tank B34-3
Author Topic: Holding tank B34-3  (Read 2825 times)
jannis1995
  • Boat Model: Bavaria 34-3
Holding tank B34-3
« on: November 29 2023, 09:33 »
Hi - we recently bought a B34-3 (with the front head) from 1999. While the boat has a y-vent installed in the head it does not currently have a holding tank installed. As the cabin room is quite limited in the head, we assume the holding tank should be fitted under the front v-berth. Does anyone in this forum have a B34-3 with a holding tank installed and could share some pictures of the installation / holding tank model installed?
Thanks!
Best
Jannis
Re: Holding tank B34-3
« Reply #1 on: November 29 2023, 12:03 »
The factory fit was in the forecabin, but not many were made. you will need to have a tank custom made to make the most of the space. you should aim for a capacity of 40l+
Worth looking at this site as there is good advice on designing systems and they may well have made a system for your model boat. Appreciate they are in the UK and expect there will be a similar source where you are. On the other hand they are arguably the best in the business and will export.
tek-tanks.com
jannis1995
« Reply #2 on: December 01 2023, 07:35 »
Thanks for tour response, symphony2.
Does anyone in this forum have pictures of their (custom made) holding tank in the B34-3?
Also appreciated if you could tell where the pipes for the siphons (which I assume are needed since the toilet and holdingtank will be below the waterline) - would this be behind the head locker?
