Diameter of rudder shaft Ocean 47
Author Topic: Diameter of rudder shaft Ocean 47  (Read 3173 times)
« on: November 14 2023, 12:49 »
Maybe some can answer my question. I need to  know the diameter of the rudder shaft on my boat because I wish to  connect  an autopilot  drive  unit. ( The steering quadrant is fixed half way up the shaft making it difficult to fabricate a strong fitting for the drive unit bracket. So  I want to  install the drive unit lower than the quadrant with an arm coming off the shaft. It would be good to  have that piece before I set off to  the boat in Turkey as sourcing that piece could take up  much  time. My idea is to  adapt  and engine connecting rod ( old truck engine with a fat crankshaft and long stroke.
I should think  the shaft diameter for the Ocean would be the same for single wheel  designs with similar sized boats from the  J & J stable.
Re: Diameter of rudder shaft Ocean 47
« Reply #1 on: November 14 2023, 14:05 »
Probably can find the plans on the Jefa server, but you still have to measure as the shafts have stepped diameters depending on which point you want to attach to.
https://jefa.com/ftp/old_boat_spare_parts/Bavaria/
Also, not sure connrods can handle angular forces very well, they're kind of designed the other way. If it's big enough though :)
« Reply #2 on: November 15 2023, 16:34 »
I think you are right about the stepping Jeffa shows the bearing as 50mm diameter  which does not look right.  I was hoping to  use a con rod from an old truck engine. Car engines seem to have short strokes compared to older engines and it will need a long stroke to minimise effort and to assist accuracy. Should be strong enough  but will need a screw in the centre to pin it to the the shaft (like the quadrant)
« Reply #3 on: November 15 2023, 23:30 »
jefa do a range of steering arms either already bored to size or pilot bored.
jefa.com/steering/products/rackandpinion/tillerlever.htm
« Reply #4 on: November 16 2023, 17:03 »
Thanks for the reference - I think I did look it up some time ago. For what is a simple lever/clamp I was surprised  by the prices.
« Reply #5 on: November 16 2023, 17:28 »
Just a sign of the times - but they work.
kavok
  • Boat Model: 40 Cruiser
« Reply #6 on: November 16 2023, 20:27 »
Jefa assure correct value/efficace for money.
But yachting never wase a cheaper activity.
In the 3 last years even less.
« Reply #7 on: December 05 2023, 21:12 »
I think the diameter of the rudder shaft is 63 mm. Any comments?
« Reply #8 on: December 05 2023, 21:48 »
Mine was also exactly 63mm. The Jefa plans were 64mm. I had made the mistake of ordering from the plans...
The stamp on the rudder bearing housing (under the antifouling) turned out to be "JP3", which was the previous company supplying rudders to Bavaria before switching to Jefa. So different manufacturer, different size it would seem.
But that's the diameter at the bottom where the bearing sits. The shaft is tapered in several steps upwards and where the autopilot sits it wasn't 63mm anymore.
« Reply #9 on: December 14 2023, 16:26 »
Good to know. I shall just have to wait until I can get back  on the boat and work it out from there.
