Pad eye of the main traveller system broken
Author Topic: Pad eye of the main traveller system broken  (Read 2099 times)
Ailatan
« on: September 27 2023, 08:32 »
I have broken the pad eye of the main traveller system.
I would like to replace with another pad eye of the same brand because all different options I found in every shop have the holes in different positions.
Does anyone know which brand is NR?
Re: Pad eye of the main traveller system broken
« Reply #1 on: September 27 2023, 09:00 »
Since the base is intact, why not remove it, drill out the two remaining bits and weld a new 'D' ring into the base..??
Ailatan
« Reply #2 on: September 27 2023, 22:27 »
Yes, that's another possibility, but as the D ring jumped into the water when it broke I need to buy a new pad eye, remove the D ring and weld it to the original piece. I thought it will be more expensive than if I could find the original piece.
« Reply #3 on: September 28 2023, 08:57 »
Sorry, I really meant that it should be an inexpensive and easy fix to fabricate a new 'D' ring from a short length of 316 S/S rod of suitable diameter....
Ailatan
« Reply #4 on: September 29 2023, 10:27 »
Thanks, it's true, I will try to find a local workshop
