Pad eye of the main traveller system broken
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Pad eye of the main traveller system broken (Read 2106 times)
Ailatan
Able Seaman
Boat Model: Bavaria 44
Boat Year: 2003
on:
September 27 2023, 08:32 »
I have broken the pad eye of the main traveller system.
I would like to replace with another pad eye of the same brand because all different options I found in every shop have the holes in different positions.
Does anyone know which brand is NR?
Logged
Old Salt
Boat Model: Bavaria 38 Lagoon
Boat Year: 1990
Re: Pad eye of the main traveller system broken
Reply #1 on:
September 27 2023, 09:00 »
Since the base is intact, why not remove it, drill out the two remaining bits and weld a new 'D' ring into the base..??
Logged
Ailatan
Able Seaman
Boat Year: 2003
Reply #2 on:
September 27 2023, 22:27 »
Yes, that's another possibility, but as the D ring jumped into the water when it broke I need to buy a new pad eye, remove the D ring and weld it to the original piece. I thought it will be more expensive than if I could find the original piece.
Logged
Old Salt
Boat Year: 1990
Reply #3 on:
September 28 2023, 08:57 »
Sorry, I really meant that it should be an inexpensive and easy fix to fabricate a new 'D' ring from a short length of 316 S/S rod of suitable diameter....
Logged
Ailatan
Able Seaman
Boat Year: 2003
Reply #4 on:
September 29 2023, 10:27 »
Thanks, it's true, I will try to find a local workshop
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
