130S-D SAILDRIVE with Ambassador rope Cutter
Author Topic: 130S-D SAILDRIVE with Ambassador rope Cutter  (Read 3135 times)
bravado
« on: July 10 2023, 19:09 »
Has anyone had trouble fitting this rope cutter and the prop cone locks the propeller?
Re: 130S-D SAILDRIVE with Ambassador rope Cutter
« Reply #1 on: July 10 2023, 22:27 »
Should not be a problem. Do you have the correct anode? normally no need to remove the propeller to change the anode. Is this a new installation and is it a standard Volvo fixed blade propeller?
bravado
« Reply #2 on: July 11 2023, 17:44 »
Yes new install. It seems there is a bolt to change on the sail drive unit which is not in the instructions
marp
« Reply #3 on: July 23 2023, 18:07 »
I have 130s on my B39 and to change anode no need to remove prop.
