2004 Bavaria 32 listing to starbord
Author Topic: 2004 Bavaria 32 listing to starbord  (Read 2029 times)
andrewj3
« on: July 10 2023, 00:13 »
I have a 2004 Bavaria 32 that has a persistent list of 3 to 4 degrees to starbord. I have 2 AGM and 1 starting batteries, fuel tank and tank for the WC on that side. Water tank is on the port side and even when full does not correct the list. Is there a remedy or should I add some lead to the port side?
Krumelur
Re: 2004 Bavaria 32 listing to starbord
« Reply #1 on: July 10 2023, 06:54 »
I found that various stuff adds to generate listing. For example here's a list of all the heavier stuff I'm carrying around:
- spare anchor
- spare fuel
- tools
- gas bottles
- spare parts
- outboard engine
- water/beer bottles
- scuba gear (tank, lead)
- electric scooter
- ropes, lines
Maybe you can start with moving around some of these things before adding additional weight?
Lazy Pelican
« Reply #2 on: July 10 2023, 09:27 »
Our B39 2006 has always listed to Starboard. It’s something you learn to live with.
« Reply #3 on: July 10 2023, 10:03 »
Pretty standard for the reasons you mentioned. Difficult to change because there is little you can do to add weight permanently to the other side. Has no effect on the performance of the boat so just live with it.
Keweetoo
  • Boat Model: Bavaria 35E
« Reply #4 on: July 10 2023, 13:44 »
We have same issue with batteries, fuel tank, lockers all on SB side. We even had to raise the waterline as the waterlevel was above the AF line and always fouling.
