Seized rudder 2
Author Topic: Seized rudder 2  (Read 1726 times)
Laysula
  • Boat Model: 350 lagoon
  • Boat Year: 1994
Seized rudder 2
« on: May 14 2023, 18:38 »
I have a Bavaria 350 and the rudder has been a bit stiff so while it was out I thought I would drop the rudder a bit and clean up the shaft. I have got it down about 6 inches and it is now stuck very solid.The top bearing is free and in good order. The bottom bearing is seized in the housing and won't move. I presume that the housing has corroded and is compressing the doughnut onto the shaft. Any Ideas apart from the big hammer?
SorinCT
  • Boat Model: Bavaria C36
Re: Seized rudder 2
« Reply #1 on: May 14 2023, 19:22 »
You can break and chisel off part of the lower bearing housing. Just make a groove and then bring out the big hammer. I've seen it done on other Jefa bearings and after using the big "persuader" it comes off.
