Bavaria furniture colour from 2003
Author Topic: Bavaria furniture colour from 2003  (Read 3172 times)
marioxp
« on: May 11 2023, 09:01 »
I have to repair the damage on the table and the wardrobe.
It is a minor dime size damage that I intend to put a veneer on. After that, I should paint the veneer to look as similar as possible to the original colour.
It is a Bavarian from 2003 with a characteristic reddish-orange color of the wood. The picture shows a boat that has the same color as mine, I believe that all Bavarians of this year had the same colour of furniture.
Has anyone restored furniture on a bavaria of a similar age, how to get this bavaria reddish orange color?
I found bondex paint for wood, I tried with teak wood colour, but I don't have this reddish orange color. Mahogany seems too dark.
https://www.bondex.de/produkte/innen/holzbeize
Re: Bavaria furniture colour from 2003
« Reply #1 on: May 11 2023, 09:57 »
The actual veneer is sapele ,which is a variety of mahogany. I have repaired small bits of water damage by gently rubbing back the area ,and surroundings then several thin spray coats of varnish [in uk Lidl] Geoff
marioxp
« Reply #2 on: May 11 2023, 10:21 »
Thank you very much Geoff.
This damage is not of a large area, but the entire upper part of the wood has been torn off, so I have to put a veneer on it, I will try to paint it with mahogany, it is probably the most similar to sapele.
But for decolorization from water I will use your advice.
SorinCT
  • Boat Model: Bavaria C36
« Reply #3 on: May 11 2023, 10:33 »
Some people did nice work with Ronseal Deep Mahogany Satin.
marioxp
« Reply #4 on: May 11 2023, 11:02 »
Unfortunately in my part of the world (Croatia, Slovenia) it is hard to get Ronseal, and many other brands that you refer to.
« Reply #5 on: May 11 2023, 14:03 »
If your boat is like mine , inside all the cupboards under the deck the top surface is sealed off with a thin sapele ply panel . Take it out [2screws] it will be a perfect match . The cupboard liner is never seen . Geoff
« Reply #6 on: May 11 2023, 15:48 »
The 2003 on boats are different from earlier boats and the veneer is lighter and with a more glossy finish. Not so easy to match.
