120 saildrive gear drive seals
Author Topic: 120 saildrive gear drive seals  (Read 3637 times)
« on: April 26 2023, 13:30 »
Does anyone know the size of the lip seals on the Volvo saildrive shaft,
The actual size, not the number.
Re: 120 saildrive gear drive seals
« Reply #1 on: April 26 2023, 15:38 »
2.0 x 1.25 x 0.375 inches
Klausen
  • Boat Model: Bavaria 37 cr
« Reply #2 on: April 26 2023, 15:45 »
metric: 31.75  50.8  9.52
« Reply #3 on: April 27 2023, 09:28 »
Thank you both, looking to find the manufacturer.
Klausen
« Reply #4 on: April 27 2023, 13:37 »
why not from parts4engines?
« Reply #5 on: April 27 2023, 15:15 »
The seals are available from simply bearings in UK. If you choose viton they last longer and use stainless garter springs. Dont forget that if you have wear grooves in the shaft 3 seals x1/4 in will fit the same space as 2x 3/8th and the seal lip will fall on clean shaft. Mine has been like this for over 10 years. Geoff
Jeffatoms
  • Boat Model: Ocean 38
  • Boat Year: 1998
« Reply #6 on: May 05 2023, 15:28 »
I may have one at the shop that has two years use on it.  I have the upper gear housing but sold the leg earlier and I'm not sure what went.  I'll have a look later today.  If so, it is available.
