Thanks Geoff, I'll plug on with the rebuild and put the rest together. What vexes me somewhat is how the dog clutch disengages with the big wormgear, as that big spring appears to always be loaded, so how do you let it freewheel out? I mean, I guess it must all work as that was how it came apart...
Photo from the deconstruction process (to excuse to treacle like oil!):
Yngmar, thanks! I had my doubts about the bearings inside the oil seals and had regrets I hadn't greased them... but they are behind the oil seals (and are open bearings), so that makes sense. I've seen write-ups where it says do not grease the "Braking surfaces", now where the hell is that? Or do I just grease the hell everywhere?
So grease here (plus the shaft and woodruff key):
Then put on the clutch cone, and grease that?
And then a light bit of grease on the rest of it?
