BC 36 sole repair replacement
Author Topic: BC 36 sole repair replacement  (Read 2035 times)
Goboatingnow
« on: December 01 2022, 13:31 »
My faux teak holly sole boards have a collection of dings  wi daring eggs people for to refurbished these. ?
Re: BC 36 sole repair replacement
« Reply #1 on: December 01 2022, 15:23 »
Uhm. What?  :))
« Reply #2 on: December 01 2022, 17:05 »
Not sure you will be able to repair it as it is a plastic laminate glued to plywood and once the 1mm thick top laminate is broken all you can do is fill it with a matching filler.
You can buy a similar product, either just the 1mm laminate or laminated to plywood from here  robbins.co.uk/our-products/marine/marine-plywood-panels/ although probably not a lot of help if you are in Greece.
