D2-55 not working anymore
Author Topic: D2-55 not working anymore  (Read 4021 times)
Krumelur
« on: November 29 2022, 14:44 »
My boat is back in the water after 3 months.
I started the engine and it ran but not smoothly.
I added some power but after a while it would run da badly that I turned it off.
Before I retry i wanted to know if there’s anything obvious I should check so I don’t run a chance of severely breaking something?
I noticed one odd thing: at the top of the engine at the lid, there’s cooling liquid dripping. When I loosened the lid of the cooling liquid expansion tank (level was between min and max), cooling fluid would be pressed out.
Also attached an image. If I open the marked lid, cooling fluid will come out as if being pushed by force.
Krumelur
Re: D2-55 not working anymore
« Reply #1 on: November 29 2022, 15:10 »
Mkay….so the engine not running was me not priming it.
The coolant dripping though…?
Daryl28
« Reply #2 on: November 29 2022, 17:33 »
Do you have anymore pictures? I don't like the look of the oil seeping out around the head. Maybe someone more experienced could give advice, but it doesn't look right to me.
Krumelur
« Reply #3 on: November 29 2022, 17:59 »
There's no oil seeping. It's sweating a bit, but that's ok given its age.
« Reply #4 on: November 30 2022, 15:21 »
The only d2/55 that I have used was on a Beneteau 411 .It had a manual pull engine stop control. If the engine stop was not FULLY pushed back in the engine huffed and puffed like crazy. Geoff
Krumelur
« Reply #5 on: November 30 2022, 15:26 »
That's a good tip if the engine stutters. I'll try to remember it.
This time it was luckily only missing priming :-)
« Reply #6 on: December 02 2022, 02:44 »
If the engine ran rough soon after starting, it sounds like a fuel issue, particularly if the engine ran more roughly when accelerated. I would check the filters ( see if dirty)  and the off/on switch ( may be blocked by diesel bug).
Do you have a good water flow out of the exhaust? If not, check the salt water system. ( Strainer, Impellor, Heat exchanger, exhaust elbow)
kavok
  • Boat Model: 40 Cruiser
« Reply #7 on: December 02 2022, 11:19 »
Do you use the correct starting procedure?
Push on,  wait for double bip,  then push with fast pression start, you heard another bip, wait 30 seconds and push start again.
Krumelur
« Reply #8 on: December 02 2022, 11:33 »
Thanks for all the responses. The problem is already solved.
The motor has a push button to prime it. It did not get enough fuel and stuttered because I forgot to use that priming pump.
It's located on the left hand side, in vicinity of the emergency stop lever.
kavok
« Reply #9 on: December 02 2022, 20:52 »
I have same boat and same engine.
Could you publish an image of this pump please?
Krumelur
« Reply #10 on: December 02 2022, 21:04 »
The black thingy can be pushed.
Now that I look at it closer: I think this is an additional fuel filter that was added later. The bracket holding it does not look original.
« Reply #11 on: December 02 2022, 22:10 »
The filter is original, although the bracket does appear to have been replaced.
Edit: The original bracket was replaced by a different part number, so perhaps your engine had a failed bracket and an improved bracket was fitted.
kavok
« Reply #12 on: December 03 2022, 17:15 »
The black button is used only when you need to purge  air from fuel system when change fuel filters.
Did you tried the starting system I suggest you? It is important the function of preheat of the little spark plugs.
