Leaking Windows Cruiser 33
Author Topic: Leaking Windows Cruiser 33  (Read 2034 times)
Lauramartin
  • Boat Model: Cruiser 33
« on: November 06 2022, 18:41 »
On my 2014 Bavaria 33 Cruiser I am having a problem with the port side window leaking. Initially it was only the small opening port light. It appeared that when this was installed the process cracked the lexan . I repaired the crack with silicone and it improved. Now it appears to be the entire aft portion of the large lexan window. The cracks around the port light are also larger and I have refilled these with silicone but it did not resolve the problem? The sealant around the large window is cracked. Do I need to replace the entire window (it is 11 feet long) and if so how is it removed and reinstalled?
Laura
