Alternator voltage
Author Topic: Alternator voltage  (Read 2307 times)
elias
Alternator voltage
« on: September 14 2022, 12:44 »
Hi !
D2 55 engine , factory alternator , at 1800rpm I have house bank 13.7v and motor 14 , after 2hiurs of motoring …should I suspect something bad?
Re: Alternator voltage
« Reply #1 on: September 14 2022, 15:24 »
Sounds good, why do you think there's something wrong?
elias
« Reply #2 on: September 14 2022, 15:34 »
I had my solar controller at float , meaning that the battery bank should be topped , meaning that I should have 14,4 or 14 not 13,7v . I saw a fire on boat near me 2 days ago and I got a little concerned too
« Reply #3 on: September 14 2022, 16:06 »
With AGM batteries, ~13.7V is float voltage, so still sounds right. 14.4V means they haven't completed the absorption stage yet. Once that's done, the charger should drop down to 13.7V.
elias
« Reply #4 on: September 14 2022, 16:37 »
Hmmm I had it different in my mind, that the voltage of 13.7 on the alternator is because it drops due to absorption . So once the battery is full the alternator regulates the voltage to lower than 14.4 ?
Still thanks for the help and advice
« Reply #5 on: September 14 2022, 16:53 »
Depends on what you have on your boat. We've got a multi-stage regulator, which does go to float once the batteries have been charged fully.
elias
« Reply #6 on: September 14 2022, 17:05 »
I believe factory setup , alternator with one yellow cable coming from the engine battery , and the positive from the alternator on a Victron splitter diode and then two cables to each battery
« Reply #7 on: September 14 2022, 17:12 »
That's just a basic system; the alternator will maintain a constant voltage, it can't do anything else.  Are you measuring the voltages with a multimeter at the battery terminals?  Or relying on the Bavaria panel (which isn't as accurate)?
elias
« Reply #8 on: September 14 2022, 19:42 »
Bavaria panel and the battery voltage indication through Victron Bluetooth app
