Lateral movement of rudder - does it make a sound?
Author Topic: Lateral movement of rudder - does it make a sound?  (Read 2127 times)
Krumelur
« on: August 19 2022, 21:22 »
I read Geoff's post about lateral movement in his Bav's rudder.
My boat (2010 Cruiser 40) also has some lateral movement of the rudder.
Before our bad day at sea we motored through some long waves and I would get a "thud" sound from the rudder at specific wave-boat-angles.
Would lateral play produce that sound or does it mean something is seriously damaged?
The boat drives straight (forward and backward) and turns fine.
Re: Lateral movement of rudder - does it make a sound?
« Reply #1 on: August 20 2022, 08:11 »
On my boat it sounds a bit like someone has left a cupboard door open and it thuds it in time to the swell .Geoff
« Reply #2 on: August 20 2022, 08:59 »
It can. It's easy to check in the warm waters of the Med - next time you're swimming, dive down to the bottom of the rudder and wobble it left to right. Don't be gentle, the waves aren't!
If it moves, you will feel it and hear it - crew on deck can compare the sound to what you hear when underway (for the person underwater all things sound very different). A tiny bit of play is okay and doesn't make sounds, but if it notably moves left and right (or forward/aft - try that too), then most likely one or both of your rudder bearings are worn out. Usually the bottom one.
You can find several threads on replacing them around here somewhere, most recently done by MagicalArmchair, I think.
Krumelur
« Reply #3 on: August 20 2022, 09:19 »
That’s a very accurate description of what I hear!
I’ll give it another wobble but I assume I can make it home safely.
« Reply #4 on: August 20 2022, 10:54 »
Tightening the top nut where the emergency tiller goes (loose  locking screw first) might well improve things.
Krumelur
« Reply #5 on: August 29 2022, 09:48 »
Thank Moodymike! I did this and I was able to make about four complete turns. It might be a bit too tight now but the sound is gone.
