Bavaria 38 Holiday battery shunt
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bavaria 38 Holiday battery shunt (Read 2011 times)
Twhitt
Cadet
Boat Model: 38 Holiday
Boat Year: 2000
on:
July 01 2022, 11:15 »
Does anybody know where the battery shunt would be located on a 38 Holiday year 2000.
Fitting solar controller, and needs to be on shunt to read correct voltage for charging.
Trevor
Logged
Old Salt
Boat Model: Bavaria 40
Boat Year: 2001
Re: Bavaria 38 Holiday battery shunt
Reply #1 on:
July 01 2022, 11:37 »
There should be no factory-installed shunt an a Bavaria of this age.
But any previous owner may have installed something - you just need to follow both negative and positive leads from leisure battery until you either find the shunt or can confirm that there is none.
BR,
Tommi
s/y Anniina
Logged
tckearney
Able Seaman
Boat Model: B42
Boat Year: 2000
Reply #2 on:
July 02 2022, 14:40 »
On My B42 2001 its on the bulkhead RH side behind the switch/fuse panel
Logged
marioxp
Old Salt
Boat Model: Bavaria 36
Boat Year: 2003
Reply #3 on:
July 04 2022, 08:37 »
Battery shunt has to be on
negative
side of battery, close to battery, before any charging or load spot.
I put my direct on negative pole on battery,
Logged
Twhitt
Cadet
Boat Year: 2000
Reply #4 on:
July 04 2022, 10:06 »
Could this be a shunt?
Logged
Administrator
Boat Model: 40 Ocean
Boat Year: 2001
Reply #5 on:
July 04 2022, 10:58 »
No, that's the windlass relay.
Logged
(formerly)
Sailing Songbird
⛵️ Bavaria 40 Ocean (2001)
Twhitt
Cadet
Boat Year: 2000
Reply #6 on:
July 04 2022, 11:48 »
Thanks, not good with practical things lol.
Might not be a shunt, but having attached mppt controller to battery bank, it shows different voltage to panel gauge, which I have checked with hand held meter and is reading correctly.
Logged
Old Salt
Boat Model: B33
Boat Year: 2015
Reply #7 on:
July 04 2022, 12:41 »
A shunt would not be fitted as standard and is usually fitted immediately after the -ve terminal on the house battery bank. Most common reason for fitting one is when adding a battery monitor so all the current flows in and out of the bank are measured. Of you google battery shunts you will find an explanation as to how they work and products that are available.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
