Raymarine Pathfinder radar cable join
Author Topic: Raymarine Pathfinder radar cable join  (Read 1848 times)
« on: June 18 2022, 10:20 »
 I have a Raymarine Pathfinder radar installed. The cable has been cut & joined  under the mast.(inside the boat within the headlining void) I think this is the cause for my radar not working -  a common problem apparently. I tried soldering the wires but this has not solved the problem. I have been told its an issue concerning video  transmission. Anyone solved this - Raymarine do  not make a special plug and socket but perhaps someone else does.
Re: Raymarine Pathfinder radar cable join
« Reply #1 on: June 18 2022, 16:22 »
I think they're all cut, as they need to be so the mast can be un-stepped. Silicone grease is your friend with preventing corrosion (as it prevents moisture touching the raw copper). I dipped the wires into grease, then crimped boot-lace ferrules on all the wires and joined them in a small size choc-block which was also squeeze full of grease. Zero issues in the uhm, 6 years since.
« Reply #2 on: June 19 2022, 10:11 »
do  you have a pathfinder radar or is it a newer model?
« Reply #3 on: June 19 2022, 14:07 »
Pathfinder with RL70/RL70C.
« Reply #4 on: June 19 2022, 17:07 »
ok - then I will try again.It is possible there is a fault where the cables enters the radome but that's not so easy to check.
