Sail drive hull seal - replace
Author Topic: Sail drive hull seal - replace  (Read 2368 times)
Lazy Pelican
« on: June 11 2022, 10:05 »
Our sail drive outer hull seal (fairing) is starting to lift at the edges, so a winter job is to remove and re glue.
1. Can I reuse the old rubber fairing, or is it just easier to buy new.
2. I have a large tin of 2 pt glue for repairing our PVC dinghy. Is this suitable a suitable adhesive for the sail drive fairing?
HappyAfloat
    • www.happyafloat.com
Re: Sail drive hull seal - replace
« Reply #1 on: June 11 2022, 10:20 »
Will PVC glue stick to gelcoat?
I believe the recommended product is contact adhesive, we used this last year I will let you know if it's still working on Monday when we are lifted out!
« Reply #2 on: June 11 2022, 10:24 »
You may be able to get the old rubber fairing off without damage, depending on what glue was used.  When I removed mine last year, I had to chisel it off in bits!
The recommended glue is Bostik 2402; your 2-part PVC glue may be similar but I'd go for the proper stuff, to maximise the chance of a successful job.  It's important to sand the hull and the mating surface of the fairing before applying glue.
« Reply #3 on: June 11 2022, 11:35 »
I used Bostik two part 6 yrs ago still firmly on place.
Lazy Pelican
« Reply #4 on: June 12 2022, 08:43 »
Thanks for the advice.
Does anyone know if Bostik 2402 (or equivalent) is available in Greece?
« Reply #5 on: June 12 2022, 12:44 »
I stuck it on with Sikaflex 291i in 2016 and it's still firmly attached. Exact technique matters more than the glue - I posted about this a couple times before on here, probably will find it by searching :)
The Other Woman
« Reply #6 on: June 13 2022, 09:18 »
I made a new deal from a inner tube and stuck it on with eco stick sticks like sh*it 7 years ago and it's still there.
Cost nothing had all in the garage😀
Mick
