Which zinc anodes for Bav 40?
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Which zinc anodes for Bav 40? (Read 1773 times)
Krumelur
Old Salt
Boat Model: Bavaria 40
Boat Year: 2010
on:
June 09 2022, 22:34 »
I noticed the zinc anode located on the bow rear area is due for a replacement. Any recommendations what to use? It seems to be a circular one - but what diameter and thickness?
Also: are there other anodes, on the prop/sail drive and the rudder?
Logged
Administrator
Boat Model: 40 Ocean
Boat Year: 2001
Re: Which zinc anodes for Bav 40?
Reply #1 on:
June 10 2022, 09:13 »
There's an anode on the saildrive leg and if you have an articulated propeller, on there too (depending on the model of prop).
Logged
(formerly)
Sailing Songbird
⛵️ Bavaria 40 Ocean (2001)
Krumelur
Old Salt
Boat Year: 2010
Reply #2 on:
June 10 2022, 09:41 »
I'll go and make a dive to check. But: What is an "articulated" prop, please?
Logged
Old Salt
Boat Model: B33
Boat Year: 2015
Reply #3 on:
June 10 2022, 09:49 »
There will be a split anode on your 130 saildrive leg. standard item freely available. However if you have an Ambassador stripper rope cutter you will need the modified version. A Volvo fixed blade aluminium propeller does not have an anode but most folding or feathering propellers do and you need to check the make as the anodes are specific to the propeller. The hull anode is not critical as it is the ground for the shorepower circuit. They have fitted various type and they are odd sizes in my experience. If you have a bow thruster there will be an anode in there as well.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
