Is this a sign that the injector seal is gone?
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is this a sign that the injector seal is gone? (Read 1892 times)
marioxp
Old Salt
Boat Model: Bavaria 36
Boat Year: 2003
on:
May 31 2022, 11:16 »
I noticed that bubbles are forming around the injector. And the diesel leaks slightly around the injector.
Is this a sign that the injector seal is gone or the injector itself.
The engine is MD2030 and has 3.400 operating hours.
Best regards,
Mario
Logged
Krumelur
Old Salt
Boat Model: Bavaria 40
Boat Year: 2010
Re: Is this a sign that the injector seal is gone?
Reply #1 on:
May 31 2022, 11:37 »
Have you checked where the fuel is coming from?
In the video there's liquid at the top and the bottom (arrows).
Is the Diesel at the base dripping down and just bubbling because the engine is vibrating and it's actually coming from the top part of the injector?
Logged
marioxp
Old Salt
Boat Year: 2003
Reply #2 on:
May 31 2022, 11:42 »
I can confirm that I also saw diesel on the top of injector.
I can't tell if it's leaking from the bottom too.
Logged
Krumelur
Old Salt
Boat Year: 2010
Reply #3 on:
June 02 2022, 10:03 »
I think you’d have to figure out where it’s coming from before
further steps. But it’s certainly leaking at the top, so that’s what needs to be fixed in any case.
Logged
diverphil
Able Seaman
Boat Model: 33 cruiser
Boat Year: 2006
Reply #4 on:
June 02 2022, 20:11 »
the part with the pipe on is the return, (leak off pipe) check its not coming from the joint between the pipe and the injector, usually sealed with copper washers but sometimes aluminium washers are used, the ally corrodes and you get a leak.
Logged
nightowle
Able Seaman
S/V In Deep - 1999 Bavaria 35E
Boat Model: 35 Exclusive
Boat Year: 1999
Reply #5 on:
June 04 2022, 08:29 »
Is it possible to just tighten up each of the nuts on the injector to see if that stops any leaking? Do they need tightening to a specific spec?
Logged
Seattle, WA USA
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
