Window fastener
Author Topic: Window fastener  (Read 2536 times)
marioxp
Window fastener
« on: May 27 2022, 08:11 »
Dear,
On my bavaria one of window fastener dropped out, the screw loosened.
Problem is that I can't find the nut.
If nut is regular nut I can replace it, but how to fasten it!
You can see from the pictures that I can't approach the nut to tighten it.
Will I have to remove the whole window just to tighten nut?
If this is true this is a bad construction.
Re: Window fastener
« Reply #1 on: May 27 2022, 08:34 »
There is no dedicated nut. There should be a thread cut in the Window frame!
marioxp
Re: Window fastener
« Reply #2 on: May 27 2022, 13:08 »
Yes, you are right.
The thread is completely worn out due to corrosion.
What are my options, what do you suggest.
I'm thinking of gluing the nut with epoxy glue on the inside.
the other thing that comes to my mind is to make a thread for a larger screw.
Best regards,
MagicalArmchair
  • Boat Model: Bavaria
Re: Window fastener
« Reply #3 on: May 27 2022, 15:03 »
Golly, the trouble I had with replacing all of those when I replaced my windows. Each window probably took me two hours due to galvanic corrosion between the machine screws and the ally frame.
In your situation I would use a thread repair kit to helicoil it. Bonus being it'll then be stainless into stainless once you are done.
https://www.screwfix.com/p/helicoil-eco-thread-repair-kit-m5-x-0-8mm-14-pieces/887fr
The idea is you drill it out slightly oversized, tap it, then screw in the thread repair, then screw in the machine screw. There should be enough "meat" there to allow you to do it?
How I hated changing my windows... all nice and sea through now!
marioxp
Re: Window fastener
« Reply #4 on: May 31 2022, 09:15 »
Thx!
I will try with helicoil, i.e. some helicoil-like product.
marioxp
Re: Window fastener
« Reply #5 on: June 20 2022, 09:34 »
Thanks for the advice! I have never heard of this thread repair tool before.
I successfully fixed the thread with a V-coil, it was easy.
Krumelur
Re: Window fastener
« Reply #6 on: June 20 2022, 13:58 »
After I read your post I immediately took note to fix the wiggling screw in the aft head.
Then, I checked the other windows and noticed that all of the screws on all windows are wiggling! I tried to tighten them but they would not move - but they're not falling out either. It's almost as if the whole construction is meant to be flexible a bit. It's not the screws that are moving within their threads, but more like the complete setup of the window.
Now I wonder if something is seriously wrong with all windows or if it's meant to be like that so that the windows can be closed 100% water tight?
Have you noticed something like this too?
And related to the used inserts: did you use ones made of steel? I'm concerned about corrosion using steel coils in the aluminium frames. Not even sure if Duralac would help in this case. The surfaces are tiny.
marioxp
Re: Window fastener
« Reply #7 on: June 20 2022, 14:28 »
Unfortunately, the coil is made of steel.
And I noticed that the other screws are weak too, I don't know if Duralack will prevent corrosion completely.
As I searched the internet for thread repair, I came across special adhesives that are used when the thread is still holding a little. Maybe this could be the solution.
I understand that corrosion always occurred when you have two dissimilar metals, but you also need salt water. This are windows which are exposed to rain not salt water.
