What are the specs of the sea water pump bearings?
Author Topic: What are the specs of the sea water pump bearings?  (Read 1799 times)
Krumelur
I'm refurbishing my old seawater engine pump. Unfortunately I had to destroy the two ball bearings because they wouldn't come off the shaft.
The part number is 860202 but these are €45 PER PIECE (!) with Volvo. This is silly.
Does anybody know the specs of those bearings so I can order after market parts?
Note: I know there are repair sets but I don't need an impeller, no o-rings, and no screws. So I'm hoping to get away cheaper by ordering parts separately. (This repair set here is about 60 bucks including shipping: https://www.poseidonmarine.eu/products/sea-water-pump-repair-kit-for-volvo-penta-d2-55-d2-75-3583089-impeller-21951346?lang=de)
Re: What are the specs of the sea water pump bearings?
« Reply #1 on: May 26 2022, 21:03 »
Plenty of bearing suppliers. Read the type off the bearings you destroyed (or the photo you linked - zoom in, you can pretty much read it off their photo - 6003 2RS if I'm not mistaken). Measure dimensions of the other parts to confirm size (inner and outer diameter and width). Example: https://www.bearingboys.co.uk/Dunlop-and-Budget-Ball-Bearings/60032RS-Dunlop-Sealed-Ball-Bearing-17mm-x-35mm-x-10mm-1852-p
Krumelur
« Reply #2 on: May 27 2022, 06:19 »
How smart reading it from the zoomed in picture. Respect!
I'll double check the measurement.
Krumelur
« Reply #3 on: June 02 2022, 09:54 »
Quick update: I was able to get all parts from my local “goGlas” dealer here in Germany.
Total: €20 !!
Pump is working and I’m actually contemplating putting it back into operation and keeping the aftermarket one as a spare part.
Parts:
1x Wellendichtring 16x35x7BA
1x Wellendichtring 16x28x7BA
2x Rillenkugellager 6003-2RSH
1x O-Ring 15x3BR70
