Anchor retaining pin and Knox anchor
Author Topic: Anchor retaining pin and Knox anchor  (Read 1710 times)
MagicalArmchair
  • Boat Model: Bavaria
« on: April 22 2022, 08:47 »
Hello all!
My Knox anchor is currently secured with a bit of rope, as the pin for the anchor is missing.
  • Where would you source a new pin?
  • Would I need to drill the shank to make a hole suitable? There feels too much leverage and weight if I were to insert it through the shackle hole? Or just use the shackle hole?
Re: Anchor retaining pin and Knox anchor
« Reply #1 on: April 22 2022, 08:59 »
Any good Chandler will stock a selection of suitable Stainless Steel Drop-Nose Pins that will do the job. (Aluminium ones are too weak and may bend in a heavy seaway...)
Just measure the length you need and the inner diameter of the holes you want to use.
Drilling the anchor shank isn't really a good idea, if you need to drill then drill through the bow fitting to marry up with a suitable existing drilling on the anchor shank..
Your idea of using the same hole as the anchor shackle along with the two on the end of each 'cheek' of the bow fitting as indicated by the red line is probably by far the best solution
..Bill.
MagicalArmchair
« Reply #2 on: April 22 2022, 11:26 »
Thank you - Stainless Steel Drop-Nose Pins! That's the thing I'm looking for. Many thanks.
