Red cabel before main fuse
Author Topic: Red cabel before main fuse  (Read 2915 times)
marioxp
« on: April 04 2022, 09:26 »
I noticed that one red cable is connected before main fuse, on battery side. It is original setting from Bavaria.
Does anybody know what is this cable for? And why it was connected before main fuse?
On photo, right side is battery side, left side is load side,  you can see red cable connected to right side.
Re: Red cabel before main fuse
« Reply #1 on: April 04 2022, 09:38 »
Looks like a winch load fuse,.
Bav 38
« Reply #2 on: April 04 2022, 10:45 »
Diesel heater?
As you're supposed to let them shut down fully, they are often not wired through the isolator
« Reply #3 on: April 04 2022, 12:25 »
In standard configuration only the autopilot and the charger are directly connected (over separate fuses!) To battery plus side. If not sure, disconnect the wire from terminal and look which function is missing. Work with caution only with isolated tools, shorts on terminals could be dangerous!
marioxp
« Reply #4 on: April 04 2022, 17:44 »
Diesel heater?
No! 100% it is not diesel heater.
marioxp
« Reply #5 on: April 04 2022, 17:46 »
Charger is not.
« Reply #6 on: April 04 2022, 19:55 »
Do you have a heater?  If so, what does it run on?
« Reply #7 on: April 05 2022, 10:41 »
Based on high amperage, it would most likely be anchor windlass, bow thruster or electric winch. On our boat similar fuses feed the (factory fitted) anchor windlass.
BR,
Tommi
s/y Anniina (Bavaria 40, aft-cabin, 2001)
« Reply #8 on: April 05 2022, 10:50 »
Why not just follow the wire to see where it goes?  ;D
Petru
  • Boat Model: Cruiser 30
« Reply #9 on: April 05 2022, 20:55 »
I think that the red cable (nr 2) comes from the alternator
marioxp
« Reply #10 on: April 07 2022, 20:26 »
I think this is it!
